LT1/LT4 Tech 1993-1997
this is making me mad
Old May 29, 2009 | 04:51 PM
rondavis's Avatar
Default this is making me mad
so i just rebuilt the motor in my 95 z/28 but heres the kicker im getting coolent in my just in the heads none in the botom half i put new heads on and i know that the head gaskets are good and the motor only has 330 miles on it since the rebuild and for the life of me i can't figure it out so plz help!!!!!!
Old May 29, 2009 | 05:11 PM
were is the water getting in the head? what kind of heads? were did u get them?
Old May 29, 2009 | 05:12 PM
What does that mean? And where in the heads? Externally, or under the valve covers, or what?
Old May 29, 2009 | 07:09 PM
There you go again, asking questions. lol
Old May 29, 2009 | 07:52 PM
rondavis's Avatar
in the valve covers `i can only tell that cuz the oil that is on the fill neck and cap is white and i believe that it is from the coolant if im wrong plz tell me also the heads are stock i got them off ebay cuz i didnt trust mine and i had my michinest check them out so i know those are not the problem
Old May 29, 2009 | 08:30 PM
how does the oil in the crank case look? it could be just some condensation. clean it up and see if it comes back. are u losing water from the cooling system?
Old May 29, 2009 | 08:50 PM
rondavis's Avatar
im losing coolant and i have oil in my coolant i flushed everything out while i had it out and i think is my oil cooler is bad but i dont have any coolant in my crankcase so i feel like im running in circles with it
Old May 29, 2009 | 08:52 PM
jjz28's Avatar
sounds like head gasket or head cracked
Old May 29, 2009 | 08:56 PM
sounds like u may have it figured out. the oil pressure must be enough to hold the water out while running and a little is getting to the oil while not running but not enough to show in the oil. u must not be losing to much water.
Old May 29, 2009 | 08:58 PM
rondavis's Avatar
it is not the heads or head gaskets i just cleard 370 miles on the motor since i rebuilt it and the heads were hot tanked and magnafluxed by my michinest
