-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   Lt1 timing chain cover problem? (https://camaroforums.com/forum/lt1-lt4-tech-9/lt1-timing-chain-cover-problem-71999/)
Tom22 Oct 10, 2012 09:03 PM
I brought my 95 camaro to a repair shop because i work to often to get it done my self. The problem was i had an oil leak, thought it was the crank shaft seal but ended up being the timing chain cover. The timing chain cover on the engine apparentley was from a different year, there was a sensor missing from the lower left side if the cover, and was patched in order for oil not to leak. The patch gave out and it needs a new cover but im not sure which cover it needs. The shop bought one but it didnt fit. And there not sure which one it needs. it doesnt help the lt1 isnt the original engine. im going to go in tomorrow and date it with thee cast number, but does anyone have and other ideas? besides find a new mechanic.
I know that 95-97 had vented optis and ect..
Camaro 69 Oct 10, 2012 09:49 PM
93 and 94 had the old style opti, and the timing chain cover is different. 95 started the new (vented) opti and the updated cover. In 96 they added a separate crank sensor (the hole yours has), other than that, the covers are the same. You can use a 96 and up cover, if you plug the sensor hole well. http://www.gmhightechperformance.com...ing_modifying/
craby Oct 12, 2012 08:38 PM
3 Attachment(s)
look here LT1 Engine Information
Attachment 17701
92-94 lt1
Attachment 17702
95
Attachment 17703
96-97
Camaro 69 Oct 12, 2012 11:48 PM
^ The captions for the first two pictures should read:
92-94
95
Non F-body LT1's got the new style vented opti in 94, but F-bodies didn't get it till 95.
MKCoconuts Oct 13, 2012 12:45 AM
92-94
95
Y-bodies got them the same time as the F-bodies ('95). B-and D-bodies got 'em in '94, for whatever reason.
Camaro 69 Oct 13, 2012 01:08 AM
Yeah, that's true too. We could use a friggin chart on LT1 differences! I think the "reason" was for GM to continue the tradition of making things confusing. ;)
But you'd think the Vette and Camaro would have gotten the "good stuff" first. Or at least the Vette, as is usually the case.
MKCoconuts Oct 13, 2012 12:34 PM
Yeah a guy and I discussed that at work the other day. I'm thinking maybe they did to the B- and D- bodies first so if anything went wrong, they could fix it and not have their sports car groups getting mad........or maybe just to keep things confusing. Haha
robb676 Jul 20, 2022 04:27 PM
Repair the patch.
Y2Keglide Jul 20, 2022 07:27 PM
Originally Posted by robb676 (Post 743656)
Repair the patch.
10 year old thread.
