LT1 parts ID
So I got my LT1 project. I think I got a stock high miles motor. Cam is wiped, it looks like a lifter froze. You can tell it put metal all thru the motor.
I think the motor could be rebuild and I will save the block but I doubt numbers matchin will even matter since is a 93 z built into an 02 SS clone.
My goal would be to reuse the heads and intake on a low mile buick LT1. I just want to verify what I have.
This intake looks stock. The fuel rails are marked rochester. The guy I bought it from said the water pump was on for only a few weeks (2 I think) He only owned the car a short while before the motor blew.
THe head look like I thought they would. The rockers are very nice roller rockers with roller tips. They are marked with a bowtie and 1.6 I think. Stock?
![Name: HeadRocker.jpg
Size: 46.7 KB](https://camaroforums.com/forum/attachments/lt1-lt4-tech-9/32259d1501317543-lt1-parts-id-headrocker.jpg)
I can not imagine getting much bigger valves into those heads.
![Name: HeadValves.jpg
Size: 40.6 KB](https://camaroforums.com/forum/attachments/lt1-lt4-tech-9/32260d1501317543-lt1-parts-id-headvalves.jpg)
Intake ports look stock and untouched.
![Name: Head_intakeport.jpg
Size: 43.3 KB](https://camaroforums.com/forum/attachments/lt1-lt4-tech-9/32261d1501317543-lt1-parts-id-head_intakeport.jpg)
I was told that like the water pump the Opti was replaced just before the motor blew. I can not find any markings on it. Is that a bad sign of a cheapy? I also found a brand new set of Napa plug wire, yea I will not be using them.
![Name: Intake_WP.jpg
Size: 59.9 KB](https://camaroforums.com/forum/attachments/lt1-lt4-tech-9/32258d1501317543-lt1-parts-id-intake_wp.jpg)
![Name: opti.jpg
Size: 47.7 KB](https://camaroforums.com/forum/attachments/lt1-lt4-tech-9/32262d1501317543-lt1-parts-id-opti.jpg)
That intake looks like the one I have on the 94 and my is stock. The fuel rail I have has writing stamped into it but I didn't pay attention to what it said on it. My heads do not have roller rockers. Just the plain rockers. hope this reply comes through. I am trying to type on my blackberry.
I did a little research. It looks like I have these rockers.
http://www.crateenginedepot.com/stor...39-P600C0.aspx
Are these stock on the LT4?
the only thing i see that is not stock 93 lt1 is the rockers. if going with a buick lt1 be on the lookout to make sure its not a 4.3 lt1, only way to tell is the casting numbers otherwise they look the same. 4.3 is cast into the top of the block ahead of where the trans mounts.
