LT1/LT4 Comversion Kits
You can look above the pan on the side of the transmission for the casting numbers. They are usually on the passenger side above the pan and you can put them into a search engine or look for a casting number for your car. I usually just put it in yahoo and someone will have it listed. You should also be able to call GM and get the specs with the casting numbers.
