LT1 Cam Swap Guide & Info
-Bigger is NOT always Better.
-Sound does NOT equal Power. -Before selecting a cam you must develop your needs/wants/plans for your car, as that is what should determine which camshaft you select. The Components Needed For A Cam Swap -Valve Springs -Roller Rockers (not needed, but highly recommended) -Pushrods (not needed, but highly recommended) -Lifters (not needed, but highly recommended) -Gaskets(front timing cover gasket, optispark seal, crank seal, water pump drive seal,throttle body gasket, intake manifold gaskets, valve cover gaskets, water pump gaskets.) -Timing Chain & Gear Set (not needed, but highly recommened) -Valve Stem Seals -Optispark(if it has not been replaced recently, it is recommened to do so now) -Water Pump(if it has not been replaced recently, it is recommened to do so now) Cams need to breath, that means a complete intake and exhaust setup. The bigger the cam the more prevalent those mods become. Automatic guys match your stall and cam appropriately Most Common LT1 Aftermarket Camshafts Cam specs Cam----INT / EXT Stock LT1---202@ .450/ 207 @ .450 (1.5RR)--- 117 LSA Stock LT4--- 203@ .476/ 210@ .480 (1.6RR)--- 115 LSA GM Performance Parts LT4 Hot Cam --- 218@ .525/ 228@ .525 (1.6RR)--- 112 LSA --- 1800-5800 RPM GM12370847 --- 234@ .539/ 242@ .558 (1.5RR)--- 112 LSA --- 2000-6800 GM12730846 --- 220@ .509/ 230@ .528 (1.5RR)--- 112 LSA --- 1800-5800 Comp Cams CCA-07-304 --- 210@ .500/ 220@ .510 (1.5RR)--- 114 LSA --- 1000-5000 RPM CCA-07-305 --- 220@ .510/ 230@ .510 (1.5RR)--- 114 LSA --- 1500-5500 CCA-07-306 --- 230@ .510/ 244@ .540 (1.5RR)--- 112 LSA --- 1800-5800 CCA-07-500 --- 206@ .480/ 212@ .488 (1.5RR)--- 112 LSA --- 1000-5000 CCA-07-501 --- 212@ .488/ 218@ .495 (1.5RR)--- 112 LSA --- 1200-5200 CCA-07-502 --- 218@ .495/ 224@ .503 (1.5RR)--- 112 LSA --- 1500-5500 CCA-07-503 --- 224@ .503/ 230@ .510 (1.5RR)--- 112 LSA --- 1800-5800 CCA-07-464 --- 202@ .550/ 212@ .546 (1.5RR)--- 113 LSA --- 1000-5000 CCA-07-465 --- 210@ .560/ 218@ .550 (1.5RR)--- 113 LSA --- 1200-5200 CCA-07-466 --- 218@ .570/ 224@ .565 (1.5RR)--- 113 LSA --- 1800-5800 CCA-07-467 --- 230@ .576/ 236@ .570 (1.5RR)--- 113 LSA --- 2000-6000 CCA-07-468 --- 242@ .584/ 248@ .579 (1.5RR)--- 113 LSA --- 2200-6200 Crane Cams CRN-104227 --- 210@ .479/ 224@ .518 (1.5RR)--- 112 LSA --- 2000-6000 RPM CRN-104228 --- 210@ .479/ 224@ .518 (1.5RR)--- 112 LSA --- 2000-6000 CRN-104241 --- 218@ .498/ 218@ .498 (1.5RR)--- 116 LSA --- 2800-6500 CRN-1449555 --- 210@ .531/ 218@ .531 (1.5RR)--- 114 LSA --- 1900-5600 CRN-1449571 --- 210@ .531/ 218@ .531 (1.5RR)--- 112 LSA --- 1000-5800 CRN-1449561 --- 216@ .551/ 224@ .551 (1.5RR)--- 115 LSA --- 1500-6000 CRN-1449581 --- 220@ .551/ 220@ .551 (1.5RR)--- 112 LSA --- 3000-6500 CRN-1449591 --- 224@ .551/ 224@ .551 (1.5RR)--- 114 LSA --- 3000-6500 CRN-1449601 --- 228@ .600/ 232@ .600 (1.5RR)--- 112 LSA --- 3500-6500 Edelbrock EDL-2108 --- 218@ .525/ 218@ .525 (1.5RR)--- 112 LSA --- 1500-5500 RPM Lunati LUN-54778LUN --- 206@ .469/ 215@ .489 (1.5RR)--- 112 LSA --- 1200-4500 RPM Accel ACC-74220 --- 215@ .499/ 220@ .510 (1.5RR)--- 114 LSA --- 1200-5800 RPM ACC-74211 --- 211@ .499/ 219@ .525 (1.5RR)--- 112 LSA --- 1000-5800 ACC-74219 --- 219@ .525/ 219@ .525 (1.5RR)--- 112 LSA --- 1200-6200 |
| All times are GMT -5. The time now is 02:31 AM. |
