LT1/LT4 Tech 1993-1997
LS1 swap
Old 02-25-2007, 02:20 PM
z28ster's Avatar
Default LS1 swap
I'm taking out my LT1 that has 146,xxx miles on it and droping in a LS1 that was pulled out of a 1998 z28. The LS1 engines i know put out way more torque and power than the LT1. I'm also getting the automatic tranny with it and the ECU. My question is, will i need to fabricate or customize anything like the tranny or motor mounts in order to mount the LS1 in my car? Like what else might i need in order to do this?
Old 02-25-2007, 04:57 PM
95slvrZ28's Avatar
Default RE: LS1 swap
You're going to have to do a grip of customization to the mounts/frame. I think the tranny too. Not to mention most of the computer equipment and sensors. Good luck...
The LS1's actually don't put out much more torque than an LT1, especially in the low end, the LT1/4's are low end torque machines.
Old 02-26-2007, 06:16 AM
sellc's Avatar
Are you crazy? You can only spray 150 horsepower on them aluminum cans before they puke! Why would you give up the last cast iron mill GM made for a bunch of melted down soda cans? [:'(]
Whats an extra 200 lbs of block weight when your pushing 500 HP on NOS?
LS1 is not a bad motor mind you, but I like my motors BAD.
Old 02-27-2007, 05:11 PM
muscleman's Avatar
lol couldntve said it better myself
Old 02-27-2007, 09:17 PM
93fbodcamaro's Avatar
well sell the lt1 buy a ls1 and save a bunch of money doin it but i would just redo the lt1 and hand a ls1 its *** and laughat em
Old 02-28-2007, 05:00 PM
Pro_built7's Avatar
ORIGINAL: 93fbodcamaro
haha indeed
- don't forget the lt1 is running iron heads AND block as opposed to the ls1's aluminum head/block combo.. iron is better for the street, less expansion/contraction in the metal and you can push more hp with an iron block because it is stronger, AND on top of all that it's just the nostalgia of an iron block like te 60's and 70's musclecars ya kno? jm .02
Old 02-28-2007, 07:16 PM
95slvrZ28's Avatar
If you get an LT1 camaro that was manufactured after '93(so the '94 and up) they have the aluminum heads that the LT1 vettes came with.
Old 02-28-2007, 08:51 PM
ACTUALLY LT1'S CAME WITH BOTH ALUMINUM AND IRON HEADS DONT MATTER YEAR ALL FAND Y BODIES CAME WIT ALUMINUM HEADS AND B-BODIES WITH IRON HEADS
Old 02-28-2007, 11:42 PM
95slvrZ28's Avatar
You're right, I lied, all F-bodies and vettes came with aluminum heads...my bad.(gah, I really should research before I open my fat mouth, lol)
Old 03-01-2007, 11:56 PM
lol it happens were all not perfect [sm=owned.gif]
Quick Reply: LS1 swap
