LT1/LT4 Tech 1993-1997
loosing coolant
Old 12-01-2007 | 10:44 PM
95camz28's Avatar
Banned
Default loosing coolant
i just did a head job on my 95 z28 and havent even put 5 miles on the car and it's not bubbling through the radiator like before i did the heads but i keep losing antifreeze fast and it gets hot instantly.
Old 12-01-2007 | 11:26 PM
02StanGT's Avatar
Default RE: loosing coolant
That sucks.
Old 12-02-2007 | 08:30 PM
ryan88z's Avatar
it might be getting hot quick because you still might have air in the system. thats all i can think of unless you allready tried it.
Old 12-04-2007 | 01:43 AM
94 z28's Avatar
bad head gasket? forget to put head gasket on? warped heads?
Old 12-04-2007 | 04:28 PM
I'm voting for air in the system too. Did you bleed the system after getting it allback together?
Old 12-04-2007 | 06:02 PM
95camz28's Avatar
Banned
i got the heads shaved new gaskets everything and i bleed the system it's pissing me off how it's doing the same thing again
Old 12-04-2007 | 06:18 PM
Obviously, the coolant has to be going somewhere! If you know for absolutely sure that you have no air, and that your system starts out full, and that your engine isn't pouring out coolant externally, then you have to be losing it internally. Depending on where it's going, you should either have white smoke pouring out the exhaust, or it's going into the oil pan. Check your dipstick to see if the oil level is way up.
Old 12-05-2007 | 04:24 PM
95camz28's Avatar
Banned
i checked my oil and it's normal but it drips from the dipstick and Itook the pan plug out usually water sits at the bottom but no water cam out and it doesnt smoke white.
Old 12-05-2007 | 04:48 PM
OK, you're coolant can't just be disappearing! When you did the head job, I assume you drained the coolant from the lower radiator hose which would have drained some from the block too? Keep in mind that when you initially refilled the coolant, the thermostat is closed and the coolant won't flow into the block until the stat opens. Are you sure you're not just chasing it after itenters the block?
Old 12-06-2007 | 03:41 PM
95camz28's Avatar
Banned
right now i have no thermostat in it but i put like 6 gallons in it.
blackbeauty1995
12-19-2013 10:00 AM
Drexg
04-10-2011 09:46 PM
itsmyjeep2
04-24-2010 11:37 AM
red star
03-07-2009 12:14 AM
AV95Z
04-24-2008 11:48 AM
Quick Reply: loosing coolant
