LT1/LT4 Tech 1993-1997
Looking for power
Old 11-11-2006, 05:22 PM
94Ztwo8's Avatar
Default RE: Looking for power
If you have a auto you want to hold the brake and give it the right amount of gas but you dont want to be brake standing it.
Old 11-11-2006, 07:00 PM
http://www.greerdragway.com/drag101.htm
Check the section on Tricks and Tips
Old 11-11-2006, 10:02 PM
shnormo's Avatar
ORIGINAL: z28pete
Underdrive pulleys on an LT1 are a waste of time & money, the only things driven by belt are the alternator, power steering pump & the AC compressor. The alternator only draws as much power as is neede to run the car, the AC compressor does nothing when the Ac is off, the power steering pump only puts on a load when the steering wheel is turned. The water pump is the biggest power drawing acessory and it does not use a pulley because in the LT1 it is gear driven. You can save a few horses at hig RPM by converting to an electric water pump, get a street rated one rather than a strip only one. Apparently you did not take a good look under the hood, you already have elecric fans. The air foil may get you 3-4 HP, the 52 mm throttle body will do nothing for power until you get to around 400HP and the engine wants the extra air. If you have a A4 transmissio go with the 3.73 gears, if you have the M6 transmission go with the 4.11 gears. If you just want to drag race, go wth 4.56 gears or 5.12 gears, but the the stock rear will probably break.
Technically speaking there is still parasitic loss with the powersteering pump. You ever try to turn it with fluid in there? The pump is still moving around in the fluid even if the fluid is not going anywhere. Even still, there is not enough drag to make a HUGE difference. He is correct about the water pump. I still wouldn't recomend an electric one if it is still used on the street since the Electric water pumps have about a 30,000 hr lifespan. If you go with the 52mm Throttle body with out any other major modifications, such as porting, polishing and a good performance exhaust, you will actually lose some throttle response and vacuum.
MaxTheKiing
08-23-2010 03:21 AM
rbeard
82-92 V8 Tech
08-09-2009 12:11 AM
dkblind87
LS Series Tech
07-27-2009 05:35 PM
IBADRIDE
07-13-2006 01:44 AM
Quick Reply: Looking for power
