LEAKY WINDOWS
LEAKY WINDOWS
ANYONE KNOW HOW TO FIX THE LEAKY WINDOWS DUE TO NOT SEALING RIGHT. BOTH MY WINDOWS LEAK VERY BAD FROM THE TOP. I THOUGHT IT WAS MY T-TOPS BUT ITS NOT. IT LEAKS AT THE TOP OF MY WINDOWS WHERE THE GLASS MEETS THE WEATHERSTRIPPING.
RE: LEAKY WINDOWS
The only way to completely fix this permanently is to replace the weatherstripping. However, you could try rubbing silicon dielectric grease on all your weatherstripping/seals. This will help to lubricate the seals, keep them from drying out, and might slightly puff up old ones. This is good preventative maintenance, I'm not sure how it will do to fix a problem though.
