Knock Knock... Whose there?
Alright it may be a misleading title but atleast I have a sense of humor. So my Z28 threw a 332 code which means Knock sensor, so I check the sensor and its fine, so is the connector... I did a voltage test from the connector to about 8 inches up (as far as I can go) and there is no voltage...
Now before I rip stuff apart to locate the ECM I need to know where it is first and if anyone has a schematic or diagram on the wiring or if they have a code or they are color coded if there is a chart for it. Im guessing the wire came off the ECM (well its wishful thinking because a little solder and its good to go) if the wire is ok after I trace it then its a bad ECM which sucks because I cant buy one tonight. If anyone can help it would be greatly appreciated. Thanks guys |
Didn't say what year car, but there is a knock sensor module between the sensor and the ECM.
Originally Posted by z28pete
(Post 357011)
have u checked the sensor fuse in the black box.
Originally Posted by craby
(Post 357175)
I found out the wire is dark blue and is connected to D22 which is the knock signal on the pcm
Whats the proper way of doing this... since there is no voltage on the wire im guessing its disconnected or loose... sometimes my service engine soon light will come on other times it doesnt
ecu or ecm is on the rear of the passenger side fenderwell in the hole by the hood hinge. all the wires are plugin so if its a solder thing its in the ecu.
(Post 357200)
The KS module in your car is a small circuit board plugged into the PCM, unscrew the small door on the PCm to get to it. If the wiring is good you may want to swap the KS module with a good one before buying a new one. If you need a new one, get one for the LT4 Corvette, much less false knock & better power.
