LT1/LT4 Tech 1993-1997
K&N Air Intake Assembly
Old 10-06-2009, 12:01 PM
gagger84's Avatar
Default K&N Air Intake Assembly
Hey guys, I'm looking to add a K&N Air Intake to my LT1 and I was just wondering how easy or difficult it is to install. Are there any special tools needed? Thanks for your help.
Old 10-06-2009, 01:44 PM
rwing7486's Avatar
its very easy to install. All you need is a flat head screw driver. It connects right to the MAF, and instead of stopping where the air box does it will run all the way down next to the wheel well. You will see a plastic piece right below where the cone stops. Remove that plastic piece for air can get to the cone when driving (think part of it is connected to the wheel well if i remember correctly, but comes off with removing a few screws). Just be careful not to drive through big puddles.
Old 10-06-2009, 02:48 PM
sm515's Avatar
Yeah man pretty well the easiest mod to do. Bought mine from chrome intakes on ebay. 65 bucks i think with the k+n filter. I mounted a 5$ drier duct thingy that u would see on the outside of ur house on the bottom of my car to suck the air instead of a removing that plastic piece. cant see it unless on the jackstands. well worth the 65$. ltr.
Old 10-06-2009, 03:46 PM
rwing7486's Avatar
Ditto sm515. I bought one off of ebay as well....the K and N are over pirced. here is an example of one on ebay:
http://cgi.ebay.com/ebaymotors/94-97...Q5fAccessories
Old 10-07-2009, 11:19 AM
gagger84's Avatar
Thanks for the advice fellas. I'm pretty sure the addition of a new cold air intake will be the next project this fall before I have to put the car back in storage. What kinds of gains in HP and MPG have you guys seen?
Old 10-07-2009, 01:15 PM
95slvrZ28's Avatar
The K&N and Moroso are more expensive for a reason...You're going to get very little actual power increase from a "chrome intake" because it has similar cross sectional area as the stock intake piping. You'll get a little increase since it has smoother bends. The K&N and Moroso have a larger cross sectional area throughout as well as smooth bends, which is what you want for good fluid flow.
Don't expect to see any increase in MPG...
Old 10-07-2009, 01:34 PM
gagger84's Avatar
What one do you recommend between the K&N and Moroso air intake?
Old 10-08-2009, 02:01 AM
Nautical's Avatar
I would say K&N. No reason really
ive just been using them for a few
years. and they never let me down.
Also is it a "Good" Idea to remove the
plastic piece on the bottom of the car.
I never removed mine when i was installing the K&n
im guessing im getting a loss of airflow. Im
just worried about water getting up in
the filter area.
Old 10-08-2009, 03:16 AM
jamesfs912's Avatar
Another option is lingenfelter. Cheaper than K&N and moroso but with the same quality.
http://www.lingenfelter.com/mm5/merc...egory_Code=C68
Old 10-08-2009, 04:40 AM
gagger84's Avatar
the filter area.
What plastic piece are you referring to?
Quick Reply: K&N Air Intake Assembly
