issues...big supprise
ok guys, i recharged my a/c had a high side service valve leak and changed it, vac'd it down and charged it, air works awesome. but...between 1 and 2 grand the engine seems sluggish. bone stock, MSD cap and rotor, no engine lights on...fresh plugs. how ever i didnt change wires nor did i look at the back lash on the rocker arms and i am hearing some lifter rattle...watcha think?
Try resetting the ECM by unplugging the battery for half an hour, then drive the car around and see if that works.
Good luck and kill Rustanks!!! x01660 |
ill try that...
rustanks will die |
i adjusted the back lash on both banks and i noticed the elbow going into the throttle body was ripped....it runs better but problem is still there but it does it more when its warm...any ideas
