LT1/LT4 Tech 1993-1997
Intake manifold leaking.
Old Mar 17, 2010 | 11:00 PM
ssoper89's Avatar
Default Intake manifold leaking.
My intake manifold has a very mild oil leak from the front just behind the TB. I am going to replace the gasket tomorrow. Being as I am not the best mechanic I was wondering if there is anything I should worry about or may have problems with. I have the full repair manuals from GM and the process seems relatively simple. Any comments or advice would be greatly appreciated.
Thanks Steven
Old Mar 18, 2010 | 12:31 AM
i used pieces of pencils and put four of them in the bolt holes to put the manifold on as i was installing and to help guide them to the right place when dropped down. it helps to not ruin the bead of rvt on the ends. u have to get them to the right length or its a ***** to get them out so u will want to set it in and put a pencle or dowel in and measure it so there will be enough sticking out so u can grab it to get it out. i cut mine to short and had to take the manifold back off and cut up a couple more pencils. lol i liked the pencil thing because they are tight enough u have to screw them in a little if u dont trim them. dont get them to long or the manifold wont drop down or wont be enough room to get it under the overhang cant remember which.
twjohnson
Dec 8, 2012 04:23 AM
djs383
Mar 29, 2011 10:37 PM
maguilar496
Dec 9, 2008 04:44 PM
mtn_maro
Oct 22, 2008 01:10 AM
Saint_Ali
Sep 27, 2006 07:44 PM
