injectors
Replacing just one? If so, keep it GM from the dealer. Replacing only one injector with an aftermarket one can cause further issues. Fuel flow on an aftermarket injector isn't necessarily perfectly matched to an OEM one. If the new one is running richer or leaner than the others, the oxy sensor will pick up the rich or lean condition and tell the computer to either richen or lean out the fuel flow to compensate, making the engine run like crap. Been there, done that, and learned the hard way.
I am replacing the set summit has their own brand for the mustang. They don't advertise that they will work on the LT1 accel or venom i can't remember which has a set the fits either will the summit ones fit?
I know what you mean. They make something good but charge you out the nose to make it better.
