LT1/LT4 Tech 1993-1997
idle down problem
Old Oct 19, 2013 | 01:41 AM
94z28chevy's Avatar
Default idle down problem
its not a huge problem but something that bothers me when i let off the gas and turn the wheel my car stalls it also idles way down when you let off the gas like at a stop light and is just a sec away from stalling but nevers does.
the car idles at 800 to 900 rpms when when you let off it drop down to about 400 then picks back up and it stalled a couple of times when i ether pulling into my parking spot at work or into my driveway i am asuming cause of the drop in idle and then turning the wheel the car cant pick back up in time
here is what i am running for mods
Comp cam 280 XFI cam #07-467-8
Vortec 1.6 ratio 3/8 roller rockers
pcmforless.com tune
pasesetter off road y pipe
Edelbrock LT1 air gap intake
BBK 58mm throttle body
Pacesetter long tube headers
Tune from pcmforless.com
30lb fuel injectors
Old Oct 19, 2013 | 07:25 AM
check/clean the iac motor/valve. check fuel pressure.
Old Oct 20, 2013 | 12:02 AM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Check for small vacuum leaks too.
Old Mar 25, 2014 | 09:16 PM
94z28chevy's Avatar
over the winter i put the car in storage and replace a bunch of vacuum lines and last week i replaced the iac valve which the old one was really dirty but nothing fixed the problem i then tryed spraying starting fluid around the throttle body and vacuum lines in hoping to find a vacuum leak still nothing
here is a video of what the car is doing
sorry about the sound its super quite idk y
here is the video with the car running with a fuel pressure gauge hooked up
from what i read the fuel pressure looks good
liltonz23
Feb 14, 2012 06:58 PM
bryanpentlin
Oct 12, 2011 12:10 AM
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
sidewayz28
Dec 21, 2008 11:44 AM
72charger
Jul 17, 2007 05:58 PM
