LT1/LT4 Tech 1993-1997
I GOT SCREWED!!
Old 02-20-2006, 11:51 PM
Aleropwnz's Avatar
Default RE: I GOT SCREWED!!
here would be a good advice for your problem but... we can't be there looking at it... find your self a place that specializes in Transissions... sounds like the transmission is slipping... perhaps a certified GM Garage if those exist
Old 02-21-2006, 02:35 AM
94Z28SHAKER's Avatar
sounds like you got a crap rear end man, if it shifts good than it cant be the trans. i have a 94 and it has 1st gear with auto, although i have a valve job and shiftkit, with a trigger shift system, your trans should have it too.
Old 02-21-2006, 01:23 PM
dads95z's Avatar
I build these trans I am sure you have a really loose convertor. Try taking off in Drive It could be a sprag in your input housing. I will be glad to help with your diagnois. I am a wholesale dist for PTC, here in Alabama.
Old 02-21-2006, 03:05 PM
LTgun_94's Avatar
Sounds like u guys got this covered. My trans did this too. If u drove it normal it was fine. Shifted hard due to the shift kit but it was fine. But when u stood on it from a stop it would turn the wheels until u hit about 3K rpm and then it would slip but it did this in every gear. I went for a new trans but havent got it in yet. But i would listen to the specialists.
Old 02-21-2006, 08:26 PM
EricNuckolls's Avatar
Do you mean that the converter is loose from the flywheel? Its almost like starting out in 2nd. I still want to know if you can manually shift the car into 2nd?? Because my shifter thing only says 2nd Drive and o-drive.
Old 02-21-2006, 08:27 PM
I MEAN SHIFT IT INTO 1ST.
Old 02-21-2006, 09:09 PM
Well I guess the problem is solved, pulled the shifter all the back and hit the gas, it made some lovley sounds and then no more gear, Except Reverse so I drove 2miles in reverse back home. So I need a trans ayone have one close to VA
Old 02-22-2006, 02:55 PM
dads95z's Avatar
I thought the sprag might be slipping. Now we know. Be careful on a trans you will get robbed. I build them for $800 with a vette servo and kevlar band, borgwarner clutchs and a shift kit. That price is in the car also.
Old 02-22-2006, 06:08 PM
wishmaster's Avatar
Hey "dads95z" where you located, that's a hell of a deal for a good trans rebuild. And we are talking about a "700R4" correct?
  #20
Old 02-23-2006, 12:25 PM
dads95z's Avatar
700r4 or 4l60e also. Alabama, Haleyville B&B Performance 2054861528 VIC or MIKE
FSTKMARO
04-29-2013 05:51 AM
camaro86monster2506
01-06-2012 10:46 PM
Potterboy
08-29-2010 12:08 AM
onspeed
06-07-2008 05:35 AM
Z28 M4N
10-15-2007 08:14 PM
Quick Reply: I GOT SCREWED!!
