how to wire a sub into monsoon system
I have the factory monsoon set up. Im buying a sub and amp and was wondering whats the easiest way to wire it in? Can i use the wires from the back speakers in trunk area for my inputs into amp? I really dont wanna buy a new head unit (yet). Any ideas or tips?
You can get a RCA converter which will convert your high input stock signal from any set of stock speakers to low imput RCA output to your amp. You just tap your R/L speaker wires and you'll be set. It'll work but it's not the best for sound quality.
my .02 cents ditch the monsoon system get a nice deck and wire it up right
its all pretty straight forward get the install kit and a wiring adapter. the wiring is easy just color to color. and wire the remote wire to the power antenna. do you know how to hook up the amp? whats your setup going to be?
Way to hi-jack a thread bonehead.
well i have pulks in the front doors, pioneers and polk tweeters in the kickpanel... i wanna do polks in the back seat (6.5 right) and prob just 1 ten in the back cause i dont wanna loose the space for t tops and im not gna pay for a stealth box
