high oil pressure?
when I'm driving the oil pressure is normally above 40, more around the 50 range. in low rpms, 1000- 2000 its right about 40. it doesn't seem to get to or above 60 (i haven't molested it so it might at WOT) Does this seem bad?
There's 5600miles on it. Any ideas? there is an aftermarket MAF on it ( PO bought it, random upgrade huh?)
so i had it checked out by a shop when i got every fluid changed and there was some oil near the front and the rear seal. not much at all but it was still there. its not leaking by any means but some seems to be getting threw those seals. any ideas? or solutions?
Those areas aren't under pressure, but are subjected to having oil bathe them.
The seals were installed incorrectly or the crank had grooves in the seal area from the previous installation. There are sleeves that can be installed over your crank to stop the leak.
Micro Sleeve Manufactures Automotive Crankshaft Repair Sleeves
clean it and check to see if its really coming from the front seal. the water pump shaft seal can leak and run down there, the front intake manifold seal is another and the oil pan gasket can also get hard and fail to seal and leak at the front.
