LT1/LT4 Tech 1993-1997
Help!!! On side of road need help asap
Old May 4, 2011 | 06:13 PM
x01660's Avatar
The Mustang Hunter
Default Help!!! On side of road need help asap
I was getting on the freeway. in 2nd at 3500 rpm. Went to floor it and it backfired and died. It won't start. It engages, then sputters for like 20 seconds going between 300 and 500 rpm, then dies. smoke out the tailpipe and the intake manifold.
got error MALF 16 lo res fail
and map high and map low
and eeprom error.
vehicle is 95 z28
help
x01660
Old May 4, 2011 | 06:19 PM
Grandpaswagon's Avatar
Best guess, your computer took a crap. The EEPROM error makes me think that you need to call a tow.
Old May 4, 2011 | 06:20 PM
check the main computer, its in the cuby on the passenger side fenderwell next to the firewall. check for water and damaged lose or unplugged conectors. 16 is usually the opti.
Old May 4, 2011 | 06:25 PM
x01660's Avatar
The Mustang Hunter
read something about icm getting heat soaked. is that a possiblility? What are symptoms of opti going bad? icm going bad?
thanks.
x01660
Old May 4, 2011 | 06:33 PM
water in the connectors can make it go wacko. opti and pcm/ecu/ecm can make it do just what your seeing. i would say most likely the later, have not seen a failing opti set off a failing eprom code.
Old May 4, 2011 | 06:36 PM
x01660's Avatar
The Mustang Hunter
craby, i know this may be a lot, but im kinda desparate right now. if you pm me and i give you my number, will you call me? it might be easier over the phone. please let me know. thanks
Zak
Old May 4, 2011 | 07:08 PM
try disconnecting the battery for a few minutes like 5. clear the computer. the only thing i can think of besides water or bad wires. otherwixe its tow time.
Old May 4, 2011 | 08:57 PM
x01660's Avatar
The Mustang Hunter
The Silver Bullet is dead... Time to pull the motor. Back to driving the P71... damn... This sucks. Any recommendations as to what I should do or get when I get the motor out?
x01660
Old May 4, 2011 | 09:45 PM
why do you think the motor is toast?
Old May 4, 2011 | 10:30 PM
x01660's Avatar
The Mustang Hunter
White smoke from the tailpipe and throttle body. Will not stay on...
x01660
