-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   Heads/Rocker/Pushrod Install (https://camaroforums.com/forum/lt1-lt4-tech-9/heads-rocker-pushrod-install-55829/)
95redcam Oct 6, 2010 02:13 PM
Hello Everyone,
First off, I'm glad to see that there are so many Camaro enthusiasts who share a passion for these cars.
In saying so I need help keeping my 95 Z28 (60K Miles) alive.
Long story short, I blew a head gasket and had to have the heads rebuilt. I'm almost comlete with the project but I ran into a problem when I was installing the pushrods/rockers. Without the supervision of my more inclined (mechanic) cousin, I began tightening rocker bolt without turning the engine and I overtightened them as well. I immediately realized my mistake when the 4th pushrod bent when tightening.
I have bought replacment pushrods but my concern is that I could have bent a valve as well. The remaing project will be completed with some experienced help but I need to know if we should be concerned about the valves?
Your response is appreciated.
Thanks,
Jim
z28pete Oct 6, 2010 02:56 PM
The valves are much tougher than the pushrods, and I doubt you caused any valve damage by overtightening the rockers, as long as you did not run the engine.
Camaro 69 Oct 6, 2010 04:08 PM
Yeah, that "tighten the rocker arm until the pushrod starts to bow, then back off one half turn" technique never really caught on! ;)
Do you know how to do it now? http://www.chevyhiperformance.com/te...nfo/index.html
95redcam Oct 7, 2010 10:43 AM
Okay great! The engine did not run after I installed anything so I think I should be good.
Thanks for the link and yes I now have some help from someone who has done this before. Hopefully I'll have some pics up once its all done.
