Headers for a 97 LT1 SS
Hey guys just wanted some input on this situation I have. I'm looking for some headers for my 1997 SS. I'm not too knowledgable when it comes to this so all help is appreciated. Basically i'm looking for a set that will give me a noticeable power gain. I'm looking more into some shorty headers since I hear long-tubes are much more hassle to install and mess with ground clearance. Btw I will have someone install them. I found some BBKs on Jegs for about 400$ Chrome, will that be something good? And do I need a Y-pipe? I basically want to spend the least amount of $ but do want quality so at least ceramic coated. Any recommendations on which to get and what else I need? thanks
I have pacesetter long tubes with y-pipe on my car. Very easy to install (although it doesn't matter to you) and a very good bargain. You can get them with emissions for 02 sensors, AIR, and EGR if you still have all that stuff. You can get these a little cheaper than others and you will notice a difference. Not a real issue with ground clearance unless u are lowered or considering it.
don't go cheap with the header gaskets
You want dead soft aluminum such as Percys Seal 4 Good
It's such a bear to get to the header bolts that you don't want to have to try and get in there to tighten because the Felpros started leaking
2fast4u
06-04-2007 08:34 PM
