LT1/LT4 Tech 1993-1997
headers
Old 03-01-2010, 05:12 PM
r6rider's Avatar
Default headers
im looking for some hearders. i was gonna buy the long tube pacesetters for my 93 lt1 but the only make then in the race verson what should i do know cause i would like to get long tube.
Old 03-01-2010, 06:24 PM
whammer3024's Avatar
ROTM Winner
i take it you're in an emissions state?
look into hooker...not sure if they make them with the emissions
Old 03-01-2010, 08:11 PM
r6rider's Avatar
they do but the pacesetters where 300 and the hookers are 500 but it looks like that may be the way i have to go. what do you think about mid tube headers?
Old 03-02-2010, 09:38 AM
u can switch your egr and air pump stuff with a 94-96 lt1 and use the lt headers. shorties are ok but dont give much power increase. as far as i know no one makes a lt header with the egr for the 93 that fits without modifications.
Old 03-02-2010, 08:28 PM
r6rider's Avatar
thats a good idea thanks alot everything will work out with the pcm right?
Old 03-02-2010, 08:39 PM
i sure hope so cause thats what im doing. lol. from what ive learned about the egr and its more than id like, it will work. thats in theroy. lol they fit but u will have to deal with the oil cooler, passeters may not have that problem, im currently going through it right now with kooks. ill post my solution in the build thread i have for my car when i figure it out. kooks no longer claims there egr headers will work on a 93. thanks to me.
Old 03-02-2010, 09:32 PM
r6rider's Avatar
right on i have a quick question if i have a 93 motor but a 95 car and 95 pcm do is till have to get the 93 hearders or can i do the 94-97
Old 03-02-2010, 10:25 PM
did the 95 have two or four 02 sensors. thats one thing im not sure of. the 93 gets the exhaust gases to recirculate from the exhaust manifold on the #8 cylinder, it gets air for that side from the a i r pump though the same pipe at the back of the motor. the 94-97 has a separate tube to feed the exhaust gas to the egr and the air pump uses the pipes at the front to feed both sides. if u have the egr system from the 95 then the 94 97 headers is what u want. well either way that s what u want if u want to use the egr, air pump system.
Old 03-02-2010, 11:33 PM
r6rider's Avatar
wow ok the crapy part is i gave the egr to the guy i sold the motor to since i had no idea about the diffrences untill i looked it up. but i do beileve i have the air pump in storage. this is great news i thought i was gunna be stuck with shorty headers. thank you!
Old 03-02-2010, 11:40 PM
r6rider's Avatar
by the way i had the 93 motor from my old camaro that i got into a crash with and needed a shell so i bought this 95 with a rod knock. kept the shell and sold the motor just in case the top statement was confusing
Quick Reply: headers
