HEADERS
HEADERS
So yea my headers came a little loose and it blew the first to ports gasket and it makes a reallllly loud pop sound, i tryied to get in there to losen the bolts but its so hard to get renches or sockets on the bolts, is there any tool or anything that makes takin the header off easy?
RE: HEADERS
The best way to get on the header bolts is:
1)for the bolts that are accessable with s socket, use a 1/4" drive socket(mine was a 1/4" 12-point 3/8ths socket)
2)take a 12 point 3/8ths wrench and grind the sides of it with a sander until it's pretty thin, this shoudl allow you get get on some of the more hard to reach ones.
good luck...
good luck...
RE: HEADERS
when you reinstall the headers i dont know if you did this before but use some locktite on the bolts when you tighten them down it realy makes the bolts stick into the groves. Down side is that if you dont tighten them enogh this time you will realy be killing your self getting them out next time
2fast4u
06-04-2007 08:34 PM
