header question
header question
I just found a set of long tubes for a sbc 350 with the D openings for 50$ used but there notnot for a camaro... now I know the camaro needs the bend in the pipe for the steering but I was wondering if I could modify these to work... any ideas
You could modify them it just depends to what extent. If you have access to a mig welder and a bandsaw. it could require a lot of fab work to make em fit but then again you may be able to cut the headers off before you need the bend to be, and use mandrel bent exhaust tubing pre bent from summit, for the angle you need, then weld the collector back on. this may help you some.....
http://www.jalopyjournal.com/forum/s...making+headers
