LT1/LT4 Tech 1993-1997
governor on a 94 formula????????
Old Feb 27, 2007 | 06:45 PM
tyler2497's Avatar
Default governor on a 94 formula????????
when i get my car up to 105 mph it starts missing and stalling and it wont let me go any faster. is this happening because of a governor?
does anyone know how to disable it
Old Feb 27, 2007 | 07:43 PM
toml14's Avatar
Default RE: governor on a 94 formula????????
The subject says 94 formula and your sig says 93 z28 so not sure which car you are talking about but do a search for governor and you will find lots of info on this topic. The way I understand it is if you had z rated tires and a 150 speedo you don't have a limiter. If you do, the 94 can probably be overridden with a power programmer but I'm not sure with the 93. Search though and you will find lots of info the topic has been beat to death.
[/align]
Old Feb 27, 2007 | 08:29 PM
tyler2497's Avatar
im talking about a '94 formula. my mistake.
Old Feb 27, 2007 | 09:15 PM
93fbodcamaro's Avatar
pcms for less get a tune to clear the gov
Old Feb 27, 2007 | 09:53 PM
The cars that had speed limiters were set for 118. If you can't break 105, you have engine problems. Try new plugs & wires first.
Old Feb 28, 2007 | 01:27 AM
tyler2497's Avatar
ok, but I'd still like to know how to do it for future reference
Old Feb 28, 2007 | 01:47 AM
95slvrZ28's Avatar
You can either PCMforless it or you can get the Hypertech Power Programmer and override it.
Pete, are you sure it was 118? I thought it was 108, we used to own a governed Formula Firebird and it'd only make it to 108, not 118, 'cause didn't they only come with a 115mph speedo?(remeber, I was pretty young when this car was around, but I can still remeber my first trip over 100mph...)
Old Feb 28, 2007 | 09:25 AM
z28ster's Avatar
i have a 93 z28 also, and wheni bought it, it was bone stock and i did about 130 a few days after i bought it. I think pete may be right, it just may be electircal problems.unfortunatly, they do not make any sort of aftermarket tuners for our year, so you'll have to get a performence tune at your local performence shop.
Old Feb 28, 2007 | 11:06 AM
tyler2497's Avatar
how do you pcm it
Old Feb 28, 2007 | 05:35 PM
ORIGINAL: 95slvrZ28
You may just be right, they had it seta little belowthe top speed supportedby S rated tires (112 MPH), which back then were considered a step above the unrated tires that were standard on most cars. The 93scan't be reprogrammed with a hand held programmer becausethey still use removeable EPROMS.However there should be chips available from JET or Hypertech that remove the limiter. Otherwise, get a new MEMCAL chip from GM for a Z28 with Z rated tires, may have to give them a VINnumber from a 93 that was not governed.
