getting a 93-97 z28 need help..
im new 2 the fourm n need som help im buying a 93-97 z28 it will b a 6 speed n i have a couple 2 chose from n som Qs on which 1 would b worth it.what should i b looking 4 in the car. like milage n if i should buy 1 already upgraded with parts or stock? I NEED HELP plz i will plan on modding the car once i get 1
RE: getting a 93-97 z28 need help..
Make sure it looks clean and taken care of,AVERAGE mileage on a 10 year old car is 125,000. As far as aftermarket parts, thats up to you, what are you wanting to do with this car? (i.e. everyday driving, street/strip, strickly race)
its gonna b a daily driver im only 16 so it will get me to school n work but it will hit the track often i want bolt ons maybe nos i want 2 hit rlly low 13s or high 12s is that hard?
I'd try to stay away from a car that already has modifications on it, more than likely that means it's had the hell beat out of it on a regular basis, not always true, but something to be aware of. Your best bet will be a car that was adult owned and unmodified, more than likely that means it'll be taken car of better(remeber, these are all assumptions, but hey, you have to make some when getting a car). Make sure the car is kept clean inside and out, check the door jams and the areas that sit under the hatch for cleanliness, if they are clean, more than likely the owner took good care of the car. Drive the car and make sure everything runs as it should, this means that you should drive it no less than 15 minutes so the car can get warmed up. Make sure it has good oil pressure when warm, battery voltage is good etc.
ORIGINAL: 95slvrZ28
With bolt ons and nos, you could get the numbers you want without a problem
