?Fuel rail disconnect tool?
What tool is used to disconnect the 2 fuel lines from the rail? 96 LT1.
Not sure what the name is, but you can purchase a set from your local parts store for a few dollars.
Actually its called fuel line disconnect tool lol. I bought a set from autozone with varied sizes. Dnt buy the cheap plastic ones, they snap at the least amount of pressure especially on a rail that's been sitting for 16 yrs
ya make sure you get good metal ones (the ones with 2 sizes on each side are good)
Thanks for the info. Got the Lisle Kit and 1/2 and 3/8 later, the rail is off. Now for new O rings and injector tests.
Just a little advice if you dnt kno already. Put a Lil film of clean oil around the o rings
