Fuel Pressuse
is the shield still on the starter, should be a metal shield that mounts between the engine/exhaust and the starter to keep it from overheating. i use a aftermarket insulation wrap.
Hello I did some checking yesterday and the shield is on the starter I did some wire chasing yesterday and noticed the fuel pump wire connector mounted on the rear floor pan just in front of the rear end that powers the fuel pump to be a little loose and burnt a little i may need to do something with that connector i dont like whats there i can wiggle it some and the fuel pump starts working again not sure if that is part of the problem but it is not helping matters
fix it, lol. is the connector not connecting or the wire is lose and not connecting. if its the connector then you can bend the clip and sometimes it makes a tighter contact.
Hello again I am trying to remove the hard pipe that has the schrader valve in it mine is leaking is there any way to remove this line i have been reading about tig welding a bung to the end of the fuel rail just wondering if this line can be removed easy or have to cut it out
go here and click your year to download factory service/shop manual. https://www.mediafire.com/?40mfgeoe4ctti
johnson3034
05-25-2007 09:35 PM
