LT1/LT4 Tech 1993-1997
Fresh Rebuild BackFiring Problems
Old Dec 11, 2006 | 05:05 PM
z28west's Avatar
Default Fresh Rebuild BackFiring Problems
I just rebuilt my camaro motor. My problem is it is backfiring out of the intake manifold. I bored it .30 over, cleaned the blocks and heads, reground the crank, put in forged pistons, and comp cam from summit. Got a new optispark dist. I had to put it together could that be part of the problem? Maybe I put it together wrong. It has fuel and spark, the ignition coil is good. My mechanic says the rocker arms and valves are installed correctly. The gas is a mix of old and new, with octane booster. I took off the emissions related things. The air pump, the egr pipe thing on the back of the intake manifold, and another pipe that ran around back of the manifold. (not the cylinder head cooler line) I read that it shouldnt cause trouble to do this though. There is a code that says the computer is bad, but my mechanic dont think it is that because it was working when the car originally died. (it locked up because it was low on oil, and a connecting rod spun off and scored the crank.) My mechanic doesnt know what is wrong, and says it could be a lot of money to find out. Has anyone else had this problem?
Old Dec 11, 2006 | 06:43 PM
cobb1985's Avatar
Default RE: Fresh Rebuild BackFiring Problems
check your timing mine was out by 180 degrees and it was spitting fire out of the intake manifold chances are that that is what is wrong when you rebuilt it you must have lined up the timing marks but when you do it has th #1 cylinder at TDC on the exaust stroke not on the intake stroke pull you distributer out and turn it 180 degrees and see what happens.
Old Dec 11, 2006 | 06:53 PM
z28west's Avatar
My mechanic said he fixed the timing...
Old Dec 12, 2006 | 05:06 PM
If it is not spark timing, which is pretty hard to mess up if your engine is an LT1, you could still have miswired plugs. Otherwise some intake valves are failing closing fully, camshaft could be out of phase, fuel mixture could be screwed up for a number of reasons. If the engine is running, it should be setting codes, a scan tool may give you a starting point.
Old Dec 15, 2006 | 03:42 AM
jv310's Avatar
check Your Spark Plug Wires i had backfiring when my wires were arcing
ThisGuy68
Mar 15, 2015 01:02 AM
uriss
70-81 V8 Tech
Aug 22, 2011 12:04 AM
1977Camaro350
Oct 16, 2010 07:39 PM
NasteeZ
Oct 13, 2008 09:41 PM
jfk1970
Aug 11, 2005 10:08 PM
