LT1/LT4 Tech 1993-1997
flywheel
Old Apr 17, 2011 | 05:15 PM
mab6680's Avatar
Default flywheel
97 z28 vert auto trans
the pick up on my oil pump fell off so i just finished the job when i started her up to check the oil pressure and reved her a little i heard a noise it turned out the exhaust was a little out of wack but while i was hunting the noise down i noticed the flywheel was flexing a little bit i didnt find any cracks and the weight was still on it is this flex normal or is it some thing to look into thank you
Old Apr 17, 2011 | 08:33 PM
1998camarossclone's Avatar
define a little? a flexplate does just that, flexes, now if its bad enough it will leak trans fluid(makes the tc wobble on the seal)
Old Apr 17, 2011 | 08:49 PM
mab6680's Avatar
Well everytime you rev the motor up a little the flexplate would do just that flex it made it look like it was moving towards the tc maybe about an 1/8 th if a inch
Old Apr 17, 2011 | 09:15 PM
A flexplate is supposed to flex, to take up for any slight balance irregularities with the torque converter. The t.c. is a lot of spinning weight, and it could tear up your crankshaft bearings if the plate didn't flex. If all you're seeing is flex, then I wouldn't be too worried about it. But, if you can also see your crankshaft flange walk in and out that much, then you have crank bearing wear.
Old Apr 17, 2011 | 09:55 PM
what were you doing to see it flex? running the motor or prying on it?
Old Apr 18, 2011 | 04:20 AM
mab6680's Avatar
Running the motor and reving it to like 2000
Old Apr 18, 2011 | 09:05 AM
so long as its not vibrating then i would say you are good to go.
Old Apr 18, 2011 | 12:43 PM
...So long as the whole crank isn't walking in and out that 1/8th inch, you'll be good to go.
Old Apr 20, 2011 | 05:40 AM
mab6680's Avatar
no its flex and there is no vibrating
blowncamaro
Jan 5, 2010 09:44 AM
carguylt1
Nov 10, 2009 04:33 PM
glue maker
Jun 5, 2009 01:53 PM
nabisco
82-92 V8 Tech
Nov 15, 2008 04:12 PM
firefighter47
Apr 29, 2005 06:40 PM
