First attempt at doin my plugs... what a pain lol.
i have found that headers (kooks) make it harder. easier on the driver side but way harder on the passenger side. with stock i had it down to 30 minutes to change plugs. wires (if done right) are a pita no matter what. you need to get to the bolt holding the bracket in and take it off or lose enough to slide the wire in. not easy any way you do it.
so with the ebay longtubes will i need differant plug wires? i hope not.
to the orginal poster, do the drivers rear from the bottom, its pretty easy from the bottom the passenger side is all bottom except the one the alternator blocks
woh you have a 56 olds. i had a 56 super 88 2 door a long time (in the 80s) ago. still have a window for it in the shed if you ever need it. cant remember if its the windshield or back. had to rebuild the motor in it. that thing got up and went. overdrive auto to boot. got any pictures?
I do have a few cuts on my hands lol, but ill be okay. I can do the plugs and wires on my 56 olds all from the top in about 15 minutes. It is so easy. I could see certain headers making this easier. The y-pipe on my car was in the way of taking the starter out and when i saw that is when I decided to finish it on a lift. My skinny arms didnt help me enough lol. Im only about 140 lbs. BTW, any tips on getting the plug wire for the farthest one back on the drivers side into the metal shield on the side of the motor?
Without Pacesetters the passenger side was dang near impossible
ahlers
04-15-2008 05:05 PM
