fan wiring
RE: fan wiring
You can't wire the fans directly to the ignition key as they draws too much power and it will cook the ignition switch. Most cases you can use the existing fan relays and apply ground through a switch to the grounded side of the relay coil. Kinda complicated in your car because it uses 3 relaysto give the fans two different speeds.Best way is to reprogram the PCM to bring the fans on sooner.
