LT1/LT4 Tech 1993-1997
Exhaust Noise when driving ?
Old Dec 2, 2006 | 08:28 PM
Default RE: Exhaust Noise when driving ?
Be aware that clanking noises are picked up by the knock sensor, and interpreted as spark knock. The PCM will then retard the spark timing and you will loose power for no good reason.
Old Dec 4, 2006 | 10:25 AM
EggboaT's Avatar
The previous owner did install headers, I think RK brand ? and it only sounds like its leaking when I step on the gas, no sounds at idle. The ticking sound that sounds like lifters only happens when I step on the gas as well.
Joe
Old Dec 5, 2006 | 01:30 AM
urr2sloww's Avatar
I have a 94 z that has edelbrock shorty headers. I had the same problem. The headers connect to the y-pipe and run along the passenger seat and connect to the cat. The ticking or tapping sound was the curve of the y-pipe hitting the frame under the passenger seat. All I did was adjust the exhuast flange that connects the headers to the y-pipe on both sides. Spinning it seemed to adjust it at least 1/4 of an inch from the frame. Now no more tapping. Just a loud smooth screaming Z.
Chevykicksbut
Sep 20, 2009 03:14 PM
vinnysav
May 13, 2009 12:55 AM
2fast4u
Jun 13, 2007 10:05 PM
FireCamaro02
LS Series Tech
Jan 4, 2007 01:12 PM
JaySan
Jul 12, 2006 08:15 PM
