Exhaust mystery ( inputs needed)
I need your help on this one
The exhaust pipe coming from the drivers side cat (its a 96) is for some reason going too low and too close to the engine crossmember. My first thought was collapsed engine mounts, but they seems firm and strong, both when we did a torque test with the car standing still and checking them with a pry bar up on a lift. Could the cat come from another kind of LT1 car? Or some bracket got mounted wrong somewhere? As I bought the car this way, I’m clueless so ANY inputs are most welcome https://cimg7.ibsrv.net/gimg/camarof...848a6dcd9.jpeg https://cimg8.ibsrv.net/gimg/camarof...9f306b5e8.jpeg https://cimg9.ibsrv.net/gimg/camarof...5ca19eab0.jpeg https://cimg0.ibsrv.net/gimg/camarof...5576da70e.jpeg https://cimg1.ibsrv.net/gimg/camarof...837a72dc2.jpeg https://cimg2.ibsrv.net/gimg/camarof...061cf1224.jpeg https://cimg3.ibsrv.net/gimg/camarof...94fbc377a.jpeg |
wow, my 93 crossed over behind the oil pan. almost looks like someone replaced that pipe and got it a little wrong or something got bent. have you checked the shop manual to see if its stock?
Originally Posted by craby
(Post 750852)
Thing is that the pipe hanging down and onto the cross memb is a part of the drivers side cat, what you see in pict #1 and #2 is one exhaust component I have been thinking on if the trans mount some how could have compressed itself, because lifting the rear on the trans makes it look more normal, the trans mount seems to be unbroken though if you test it with a pry bar |
Originally Posted by Robroy Z28
(Post 750854)
H
I have been thinking on if the trans mount some how could have compressed itself, because lifting the rear on the trans makes it look more normal, the trans mount seems to be unbroken though if you test it with a pry bar Another thing is when looking on the bolts between the cat and exhaust manifold at pict #1, it looks like they have been sitting there for decades. Also you may notice the oil pan has been taking a hit, might be some knucklehead trying to lift the car using the pan as a lifting point I upload some picts from a 97 I found on the net as comparison (below picts NOT my car) https://cimg8.ibsrv.net/gimg/camarof...46db26fe00.jpg https://cimg9.ibsrv.net/gimg/camarof...981266d473.jpg https://cimg0.ibsrv.net/gimg/camarof...1f7c1edfec.jpg |
the motor mounts will allow the front to sag 1/4 inch or so over long time. I replaced mine and it did raise the front a bit. trans mount is stock? not a poly?
(Post 750856)
Was thinking I could measure the height on the trans mount, seems it should be 47mm (1.85') acc to spec on new ones, if it has compressed itself replace it, and if not put a spacer in-between to lift enough for the contact with the exhaust and engine cross member to cease https://cimg2.ibsrv.net/gimg/camarof...2b76f3c9b.jpeg |
(Post 750856)
trans mount gets pulled up more then down,,,, at least mine do lol if rear of trans goes up the front of engine should go down.
(Post 750888)
Still curious though how it has become as it is on my car, if it had been smacked for ex and the whole powerplant moved forward, but then the mounts should have been broken https://cimg2.ibsrv.net/gimg/camarof...11470117f5.png |
right, almost looks like something is bent. I see its been towed using that hole. can see where hook stretched it
| All times are GMT -5. The time now is 02:54 AM. |
