-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   Error code 41 (https://camaroforums.com/forum/lt1-lt4-tech-9/error-code-41-a-88116/)
32rdstr Sep 23, 2025 08:26 PM
Error code 41
Just had an error code 41 pop up on my 1994 Firebird engine. Engine would start just fine and after about 5 seconds it just quits. I noticed that when it quits all the gauges drop to off as if I were losing power (just like turning off the key). I suspect the key switch is the problem. It's an aftermarket market knock off GM switch like fond in older GM dash mounted switches. Question is: why run for a short time and then just shut off? It did clear itself after about 5 starts but don't trust it now. Thoughts?
craby Sep 24, 2025 08:52 AM
still getting 41 code? sounds like may betwo issues. test ignition wires for volts if you can get it to fail again.
41 Camshaft sensor – Circuit fault or ignition control – circuit fault/error
32rdstr Sep 25, 2025 06:51 AM
Problem has gone away and I don't know why! As far as I could tell it was electrical, but can't get it to happen again. Doesn't give me much confidence to set out on a road trip. Where I live leaving town involves lots of desert with NOTHING.
