LT1/LT4 Tech 1993-1997
Engine Swap vs Rebuild LT1
Old Sep 18, 2009 | 01:30 PM
gagger84's Avatar
Default Engine Swap vs Rebuild LT1
Hey guys, I have recently starting thinking about doing an engine swap on my '95 Z and was wondering first off, what engine would be a good fit for this car in terms of work needed for the swap, power, torque, etc and secondly, if it was smarter to do a complete engine swap or if I should just consider rebuilding the badass LT1. Thanks for your help!
Old Sep 18, 2009 | 01:40 PM
Installing any other engine besides the LT1 will require additional work, both mechanical and electrical. With proper mods the LT1 can be very competitive and streetable. Build it out to a 383, or even a 427 if want lots of torque.
Old Sep 18, 2009 | 03:06 PM
liaa777's Avatar
i agree stick with the lt1...you can do a badass 383 or you can lower your compresion and run a supercharger these engines can make BIG numbers when built right...
Old Sep 18, 2009 | 03:27 PM
whammer3024's Avatar
ROTM Winner
x100 on a rebuild...buy a spare block and build the crap out of it
Old Sep 18, 2009 | 04:34 PM
z28rob18's Avatar
i agree wit wham. get a spare lt1 and build the f*** out of it. like i did only keep the car on the road while you build the motor. 383 splayed four bolt set of sick heads big cam aww man i cant wait till i go home in october
Old Sep 18, 2009 | 04:37 PM
ROTM Winner
i'm thinking about ordering some of the new trickflow 21* heads...think those things are sick out of the box...then porting...OH GOD
Old Sep 18, 2009 | 04:47 PM
z28rob18's Avatar
i havent heard of them on a motor yet but they do flow pretty decent. the ones i got should be bad as hel! im guessin you would be ordering through AI for port 21* heads? if your plannin to run in the shootout ever the 21* heads will screw you
Old Sep 18, 2009 | 06:40 PM
gagger84's Avatar
Thanks for the help fellas, sounds like I'm rebuilding my LT1 and looking forward to creating a new beast...
Old Sep 18, 2009 | 07:00 PM
gagger84's Avatar
What's the difference between a short block and a long block?
Old Sep 18, 2009 | 07:10 PM
machine1999z28's Avatar
Short block is a block with rotating assembly only (crank,pistons,rods,cam,and such) A long block is a complete engine minus intake, covers, and accesories Is this gonna be a daily driver?
