LT1/LT4 Tech 1993-1997
Engine Skipping?????
Old Jul 29, 2011 | 02:58 PM
us63bravo's Avatar
Default Engine Skipping?????
When I start it up it runs fine and drives fine. After about 5-10 minutes of driving it when the engine warms up it starts skipping like crazy and when in gear bucking like crazy. I changed out all the plugs and wires but nothing changed. Im thinking either ignition module or distributor. Has anyone else had a problem like this that could help me out???
Old Jul 29, 2011 | 03:26 PM
When an engine runs fine when cold, but not when it warms up, it can generally be assumed that it's a sensor problem since the engine management system doesn't read all the sensors till it goes into closed loop mode (when the engine heats up). Are you getting a check engine light? If so, get it scanned so you can get an idea of what it may be without throwing parts at the thing.
Old Jul 29, 2011 | 03:47 PM
x01660's Avatar
The Mustang Hunter
Sounds like the ICM. They are cheap, and it's easy to replace. Get one, R&R it, and see if the problem continues.
x01660
Old Jul 29, 2011 | 08:14 PM
do like 69 is sayin and have it scanned for codes if you can find a place to do it. you have a unusual computer system in your 94 z28. its only in your year. soo it may pay off in the long run to pick up a adld setup from a place like moatts. then you can see whats goin on using your pc, easiest with a laptop. otherwise you could start testing all your sensors to see if you can find it.
numskull223
Oct 9, 2011 12:45 AM
grimr27
Jun 24, 2009 09:30 PM
xCx777
Oct 23, 2008 09:19 AM
1bert1
Jul 4, 2005 10:00 PM
