Engine Reliability??
This is the only picture I have of one of my vehicles. Not exactly an F body, but ill get one.
I just pulled up the old service receipt from the work that was done at the shop, ill attatch it and hopefully you guys can read what all was replaced. Besides the Optispark, would there be any other immediate things I should check right away?
If it shows up small on your screen, just hit ctr= to make the screen bigger.
Thanks,
Alex
Thanks,
Alex
looks like they did everything except the opti. its running ok? i do keep an extra ignition module in the car only because i drive out in the middle of nowhere sometimes. no cell and no houses in the olympics. only had one go in over 6 yrs so im probly a little too prepaired.
Oh for sure. I plan on a slow and steady build/changes to the car. I am actually planning on starting with the interior and working my way out, changing out warn out switches, ext. After that I plan on moving on to wheels/tires, bolt on parts, ext.
The nitrous reference was more to settle my curiousity.
Thanks for the responses guys.
I would suggest that with a good rebuild and proper maintenenec you should have lots of miles ahead of you. I'm going on 190K with no internal work at all, haven't even replaced a head gasket (knock on wood). I've changed my oil every 2K miles and it doesn't use any oil except when it has an oil leak. Preatty much replaced everything around the engine though.
Have you done it every 2000 miles the whole time you've owned it? How long has that been?
I'm just asking since most people do it every 3000-5000. I do it every 3000, since It never loses any and it seems to stay nice and fresh/clean.
