DTC 26 and blown Air Pump fuse
Hello,
I have a 93 Z-28 (stock as far as I know) and just recently got it back on the road after sitting for some time.
The only trouble code I get is DTC 26. It is set after the Air pump fuse blows. I have replaced the fuse twice now, but it blows soon after the engine starts.
The shop manual procedure wants you to use a TECH 1 diagnostic tool (which I don't have).
Has anyone fixed this code before without using a TECH 1 device?
Any suggestions as what to look at first?
i had the same problem and had to replace the pump. took it out and hooked it to 12 volts and it wouldnt work. opened it up and it had water in it. picked up a new one on ebay.
