Driveline Vibration after trans mount install
Hello all I think I am in the right subform here. I know this is a dead horse I am about to beat. I installed a Energy suspension trans mount on my 95z28 a4. Im getting some vibrations when driving, the shifting feels amazing other than that. I read somewhere that the poly mounts are slightly taller than stock and this causes the vibrations. I also read that the shim plate they require you to install causes this issue as well. My question is will this vibration cause damage?, im not sure if the pinion angle is off and I do not have the capabilities of checking that.
thanks |
shouldnt harm anything. maybe shake lose some screws. poly mount will transfer vibrations much better than stock. i switched back to stock.
Some people appear to get more vibrations than others after switching to a poly mount. When I did on my old 96, the difference was there but not really bad at all. You may already have other reasons for driveline vibrations, like bad u-joints, or worn bearings in the trans or rearend. The poly mount will help to make those vibes more apparent, where the squishy rubber mount was absorbing/masking it.
Originally Posted by craby
(Post 709860)
shouldnt harm anything. maybe shake loolose some screws. poly mount will transfer vibrations much better than stock. i switched back to stock.
no but the motor mounts do sag and can add to mis alignment of the drivetrain.
