LT1/LT4 Tech 1993-1997
done or shave
Old 01-26-2011, 09:39 PM
LT1ChevyBoy's Avatar
Default done or shave
Im just curious which is better quality for a longer lasting and powerful motor Dome type pistons or shaving the heads?
Old 01-26-2011, 10:27 PM
383Stro's Avatar
In both cases you are raising compression...in both cases you are also going to need to check your piston to valve clearance .080 intake and .100 exhaust. The head gasket should be selected after measurements are taken. There are many things to consider, I would advise reading this for starters http://www.carcraft.com/techarticles...tio/index.html
Old 01-27-2011, 12:18 PM
ok that answered my question thanks man
