LT1/LT4 Tech 1993-1997
diffrence between 92-94 and 95-97 opti
Old Jul 5, 2005 | 07:06 AM
CHVYLT4's Avatar
Default diffrence between 92-94 and 95-97 opti
i think my opti dist is goin out and i herd the newer vented dist like on a 95-97 lt1 is better than the earley one like on the 92-94 so my question is... whats the diff between the two other than the vented housing i know that the vntd one is a lot cheaper so and was said to be better so i was just wondering if it would work on my 93 so if anyone knows give me a holler.. thanks
Old Jul 5, 2005 | 12:45 PM
JD1969's Avatar
Default RE: diffrence between 92-94 and 95-97 opti
The newer vented opti is better, and should be fine on your 93.
Old Jul 18, 2005 | 06:04 PM
foofer1986's Avatar
I think that the timing cover is different
Old Aug 13, 2005 | 10:57 PM
The timing chain cover is different and the drive pin on the camshaft is different. The late model distributor does not fit early model cars. You can get a late model distributor cap , and with a little work graft it on the early model distributor base, otherwise you need to repace the timing chain cover and camshaft. GM does not sell distributor caps but u can get on the aftermarket. The new ones are better but they still dont like water.
miichielx
Mar 11, 2013 06:43 PM
sbcman25
Jan 29, 2010 02:01 PM
reesez28racer
Apr 1, 2008 10:52 AM
jml317
82-92 V8 Tech
Feb 10, 2008 08:01 PM
I8AFORD
82-92 V8 Tech
Jul 12, 2006 09:11 PM
