didnt pass inspection
They said my fuel was running rich. How do I adjust my fuel pressure? 93z
I don't believe that adjusting your fuel pressure will have any affect on your running rich. It is probably a faulty O2 sensor or MAP/MAF sensor. Is your SES light on? Try taking it to Kragen or Pep Boys and seeing if they will scan for codes (lots of auto part stores will).
HC (ppm) : standard 108 current reading 2846 fail
CO (&) : standard 0.60 current reading 1.28 fail Nox (ppm) : standard 6.0 current reading 951 fail These are the three things he high lighted when father in law took to get inspected. I just wrote down the high speed emission results at (25mph). Any ideas? |
A faulty O2 sensor will not always flag a code but its a good idea to check anyways. I would suggest replacing the O2 sensors anyways as it will better your fuel economy. You may also have to replace the cat which will likely be costly on your Z28. Last thing, before you take it in to have it re checked change the oil and put half a liter of methyl Hydrate in the tank this will give it a much more complete combustion, not a good practice on a regular basis however.
Sounds like you are running on six cylinders! Your state is pretty easy on you mine only allows 53, .28, 614. And I put out 00% CO% with a 12.2 dilution.
That was back in 08 though. Now I think they changed to E85 or E50 or something because the cars don't even do the speed limit. I think they are trying to burn everyones car up so they have to buy new ones! From China!
| All times are GMT -5. The time now is 07:18 AM. |
