LT1/LT4 Tech 1993-1997
didnt pass inspection
Old Feb 17, 2010 | 09:20 PM
Stillborn's Avatar
Angry didnt pass inspection
They said my fuel was running rich. How do I adjust my fuel pressure? 93z
Old Feb 17, 2010 | 10:17 PM
Grandpaswagon's Avatar
I don't believe that adjusting your fuel pressure will have any affect on your running rich. It is probably a faulty O2 sensor or MAP/MAF sensor. Is your SES light on? Try taking it to Kragen or Pep Boys and seeing if they will scan for codes (lots of auto part stores will).
Old Feb 18, 2010 | 07:58 AM
Stillborn's Avatar
HC (ppm) : standard 108 current reading 2846 fail
CO (&) : standard 0.60 current reading 1.28 fail
Nox (ppm) : standard 6.0 current reading 951 fail
These are the three things he high lighted when father in law took to get inspected. I just wrote down the high speed emission results at (25mph). Any ideas?
Old Mar 15, 2010 | 12:19 PM
Jmoss13's Avatar
A faulty O2 sensor will not always flag a code but its a good idea to check anyways. I would suggest replacing the O2 sensors anyways as it will better your fuel economy. You may also have to replace the cat which will likely be costly on your Z28. Last thing, before you take it in to have it re checked change the oil and put half a liter of methyl Hydrate in the tank this will give it a much more complete combustion, not a good practice on a regular basis however.
Old Mar 15, 2010 | 03:49 PM
CraZ28's Avatar
Banned
Sounds like you are running on six cylinders! Your state is pretty easy on you mine only allows 53, .28, 614. And I put out 00% CO% with a 12.2 dilution.
Old Mar 15, 2010 | 04:08 PM
CraZ28's Avatar
Banned
That was back in 08 though. Now I think they changed to E85 or E50 or something because the cars don't even do the speed limit. I think they are trying to burn everyones car up so they have to buy new ones! From China!
Fubba
Jul 31, 2013 11:03 AM
vilidan
Nov 3, 2009 02:18 PM
RS96LSU
VS
Nov 10, 2008 04:53 PM
6v49der
Mid West
May 3, 2008 01:34 AM
02CamaroV6
Jan 16, 2007 05:56 PM
