did a tune up and now it wont start
i have a93 z did msd coil accel 8mm wire and bosh plugs and i took off the distributor cause i didnt think a msd would cost 500 bucks so i put the old one back on and now she almost fires but doesnt start and now im stuck any help please and thanks
double check the wires to make sure you got them in the right places. then check again. make sure they are on all the way. including the coil wire. check all your plugins that are in the area of where you have been working.
No, there's a notch in the shaft. The only way you could put it on wrong is if you forced it with a sledge hammer.
you most likely have a couple plug wires crossed, its not hard to do even using a diagram.
http://www.shbox.com/1/opti.jpg
http://www.shbox.com/1/93_ign_system_schematic.jpg
heres the home site for shbox, great place for info.
http://www.shbox.com/1/4th_gen_tech1.html
