delete air pump
yeah r6 shouldnt be a problem. took mine off during a build a few months ago, plugged the lines at the sources and just left the wire unplugged. no codes.(93 camaroz auto). unrelated but i left the oil cooler off too....if ya got one of them....
Any particular reason that you're wanting to pull the A.I.R pump? You save a couple pounds of weight, but that's about it. The pump only runs for a short time at startup and it's an electric motor, so it doesn't take any power unless it's on. The car should throw codes when you remove it as well.
o really some guy just told me it would free up a couple of ponies but he didnt say anything about throwing a code but if i got it tuned ( cause i have the motor out doin a rebuild) could i tell them to disable that code so it wont pop up
You're not going to gain any h.p. by disconnecting the AIR pump. Disconnecting it would be strictly for cosmetic reasons or to free up some space. If you disconnect the hoses, nothing will happen. If you unplug the electrical connection to the pump, your SES light will go on.
I've already tested mine to see what happens. You can unplug it, it won't do any harm. But you would have to live with having the SES light on all the time, plus the radiator fan will turn on as a default. To get rid of it totally, you would need to get it tuned out of your computer. Unless somebody knows of an electrical bypass to fool the computer. I'd be interested in that.
