COOLANT LEAK!!!!!!
Ok, so this past weekend I changed my coolant. I drained everything put water in it and let the car warm up slightly to get all the sludge out, did this twice, and drained again. I put the new in and havent had a problem. However, when I park on a level surface coolant runs out like water, not a drip, its a good stream. It looks like its coming from a hose near the serpentine belt pulley. There is a little coolant on the hose but not enough to support the idea of a huge stream. I checked the bleed screws thought maybe I didnt tighten one, nope all good. Also the car isnt overheating or showing signs of a low coolant level. What the hell?!?!?!?
akohnz
akohnz
I did a pressure test on the system and the heater core hose coming from the from part of the engine block near the serpentine belt pulley's had a hole the size of a small nail in it. Couldnt drive it because the direction of the leak was aimed at the block. I ended up cutting the hose off and putting a new one on with some hose clamps. I know its really high pressure right there considering I had to cut the original metal hose clamp off with a saw, hopefully it will hold.
In the process of doing all this I unhooked the battery and my head unit was on. I didnt turn the car on or anything. I rehooked the battery and now my cd player wont work. I cant even get it to turn on, I didnt do anything, didnt even touch the wires, I wasnt in the area of the wires. Help please!!!!
akohnz
akohnz
It could be a fuse or it could be a security thing on your system. The stock Delco-Bose system will lock out the radio if it is disconnected from the battery, and it will stay locked out until the right code is entered.
