codes
If so, those are O2 sensors which is a quick fix.
As for the p0336, is the car stuttering or acting like the ignition timing is off? If so, that's a crankshaft position sensor
if you have the stock exhaust manifolds it's not as easy as those of us who have long tube headers because we can change O2's without lifting the car up.
At your local parts store you will find Bosch O2s but they can order Delco for more $$$. As for me, I use NTK (a division of NGK) and they cost less than Bosch and work just fine.
I run NGK spark plugs and o2 sensors
ok maybe someone can figure this one out cause it makes no sense i have a code reader and have cleared the codes a few times before and the light always came back on by the time i backed out of my drive way today i unpluged the maf sensor and pluged it back in while the car is running dont know why but i did i then hooked up the reader to see if it threw a maf code and it did i cleared the codes again but the cel never came back on i drove the car for over an hour and still no cel and she is running much better now im stumped anybody have a clue
could be in limp mode and not depending on the sensors. unpluging the maf would make it go to limp mode and run on preset info and not sensor info. it should have went back to closed loop after shutting it off for a time and bringing it back to operating temp.
ok i just took a 250 mile round trip to long island and the cel light came on about 175 miles into the trip i hooked up the scanner and the same codes came up the o2 sensor bank 1 position 1 and bank 2 position 1 are these the ones before ar after the cats also on my scanner and the o2 sensors that are giving the codes stay at a steady 85 and the ones are bouncing all over the place in the mid to high 100's is this normal
