LT1/LT4 Tech 1993-1997
clutch
Old Apr 24, 2007 | 06:19 PM
mcnair's Avatar
Default clutch
I had a new clutch put in my 94 z28 and now it won't disengage till it's almost on the floor. Checked fluid level- o.k. is this normal or am I missing an adjustment somewhere?
Old Apr 27, 2007 | 10:47 AM
derrickdiggler's Avatar
Default RE: clutch
I would check to see if the fork came off of the throw out bearing...or even to see if the slave cylinder that is used to move the throw-out bearing is working or if the line has been damaged.
Old May 1, 2007 | 05:46 PM
mcnair's Avatar
Default RE: clutch
the clutch works fine except that I have to go all the way down before it will work properly. Must be in the hydraulics. Thanks
Old May 22, 2007 | 09:37 AM
95POLOVERT's Avatar
Default RE: clutch
Dude if they turned your flywheel thats the problem taking away material screws up everything since theclutch works in reverse, also ceck that the plastic cup on the end of the slave is ok, i've seen that too. The block that the slave mounts to can be ground or machined down to adjust disengagment.
Old May 22, 2007 | 12:30 PM
Default RE: clutch
Like 95polovert said, if you had your flywheel turned they should have given you a spacer to compensate for the amount of material removed. If it wasn't provided then your pedal will have to be depressed farther.
dogdog130
Jun 28, 2012 04:28 PM
locotrician
May 16, 2009 11:18 PM
bluegreenta
Dec 21, 2008 09:24 PM
Rise65
Nov 8, 2007 10:58 PM
Pro_built7
Apr 10, 2007 02:07 AM
