Click... click wont start
and by the way... so you are cirtain that only the AC and Starter are the only two things to click under the hood... what if there is a click( clicks immediately when turned to on position, not start ).. what could possibly be going out.. because i know its not suppose to click.. lol.. and sometimes it doesnt even click at all, and just reciently it died again, when i tried to start the car it did a series of 4 irratick clicks in the on position... i have a funny feeling whatever is clicking is causing all my problems..
the fuel pump comes on when u turn the key on. u need to clean (use wire brush) the terminals and wire ends at the battery and at the juntion box, its on the passenger side by the battery. its red and should have battery and other wires coming to it, also clean the ground juntion wire ends, its in the same area.
ill do that.. they looked pretty clean when i looked at them last. i was also reciently informed of a run relay, where is that located? i also put my head next to the gas tank and heard the pump lol. havent changed the filter in three years also so ill do that too..
im seeing a starter enable relay, its assoiated with the vats and says its to the right side of the supplimental inflatable restrant bracket behind the instrument panel. im lookin for a picture.
thanks for the holding my hand through all of this! haha! i am really ignorant as to the whole electical of a vehicle.. i am use to the more mechanical side than electrical.. ur awesome man!!
I have decided i am going to get her back on jack stands and systematicly check all the electrical parts with a volt meter and make sure all my grounds are grounded right and everything is in order.
but would that relay being out cause the motor to crank and not start, and also die suddenly (while driving) (or parked) (at any speed and RPM )?
#20
The ignition modual is 3 years old. i have also have some weird encounters with that distributor and have been looking for a distributorless ignition system convertion kit. is there one out there dd??
